Need some easy or free mods!
Old Aug 6, 2006 | 11:54 AM
dlricker's Avatar
I have a '93 Camaro Z28 6-Speed. Its stock, just has SLP intake, tb bypass, and a flowmaster muffler. I would like to get some power out of her without having to spend alot of cash, something i don't have. I just would like to basically know whats the best bang for my buck, or something i can do next to nothing. Thanks, Daniel
Old Aug 6, 2006 | 11:58 AM
2000GTP's Avatar
Re: Need some easy or free mods!
The throttle body bypass is one of the common free mods. If you do a "search", you will find many posts outlining the procedure as well as some other basic free/cheap mods to add a little more power.
Old Aug 7, 2006 | 09:35 PM
93transam1234's Avatar
A cut-out would be pretty cheap, under $100 installed
Old Aug 8, 2006 | 12:01 AM
gitsum's Avatar
If your fat ,YOU can lose weight! Just kidding, you could gut your cats and eliminate the silencer tube on the intake elbow. You could also do the coil/icm cooling mod.
Old Aug 8, 2006 | 01:04 AM
DaveH71's Avatar
what is the coil and icm cooling mod? also dont you need your air pump for emissions?
Old Aug 8, 2006 | 01:07 AM
StephenDeli22's Avatar
Driver mod
Old Aug 8, 2006 | 02:21 AM
MTL_Z28's Avatar
Although it isn't free, I recommend as one of your first mods a new shifter since the stock shifter is a flimsy POS. Do a search, personally I love my pro 5.0, it really should be the first mod to do on any 6-speed car. Improves the overall pleasure of driving, and insures you never miss a shift again. It's easy to install too. I was kicking myself for not having done that mod sooner.
For free/really cheap mods you have:
TB coolant bypass
MAF descreen/porting
IAT sensor relocation
removing cat(s)
disabling CAGS
Old Aug 8, 2006 | 06:09 PM
gitsum's Avatar
http://shbox.com/page/index.html This is a very good site and can help you do a number of things, including the ICM cooling mod.
Old Aug 9, 2006 | 09:03 PM
shady_ws6's Avatar
leave the MAF alone... don't F it up.....
Old Aug 11, 2006 | 06:37 AM
ZL1modified's Avatar
why leave it alone?
i know someone who screen got sucked into his intake and did some damage...
took mine out and never had a problem...
alex5366
Mar 8, 2015 11:32 AM
Caps94ZODG
25
Oct 2, 2003 06:30 AM
Fusion93Z
Sep 10, 2002 06:46 PM
Thebeast431
Aug 25, 2002 05:06 PM
GC456
Aug 8, 2002 11:53 PM
