Need to remove oil pan!
Old Jan 11, 2010 | 11:57 AM
RallyBoy1's Avatar
I have an engine hoist and I am trying to find out where to place the chain or strap in order to lift the engine on my 97 camaro. I would like to attempt this myself. Also, do I need this http://www.jegs.com/i/JEGS/555/23621/10002/-1 so my pickup won't come off?
Old Jan 11, 2010 | 03:21 PM
RallyBoy1's Avatar
Could someone post pictures of the lift points so I can replace my oil pickup?
Old Jan 11, 2010 | 03:28 PM
Bersaglieri's Avatar
I lifted the body with the cherry picker and pulled the motor out the bottom. I was actually pretty easy.
-Dustin-
Old Jan 11, 2010 | 04:30 PM
RallyBoy1's Avatar
Im not trying to fully remove the engine. I just want to know where the lift points are to lift the engine a couple of inches in order to remove the oil pan to replace my pickup.
Old Jan 11, 2010 | 07:04 PM
TPIS sells an LT1-specific device called the "Happy Hooker" that uses the bolts for the fuel rails. Hard as that is to believe, everyone who has used it seems to have positive results.
When we pulled my engine out the top, we used bolts in the holes in the heads for the exhaust manifold bolts. That, coupled with a balance bar. If you are just trying to lift the engine, you probably won't pull the manifold, though.
Old Jan 11, 2010 | 07:27 PM
RallyBoy1's Avatar
Thanks for the responses. Can I put one grade 8 bolt on the rear passenger head and one grade 8 at the front of the drivers head and lift it that way? Will it hurt anything? I gotta get my car back on the road. I have also seen where someone has put straps around the exhaust manifolds and lifted it that way. I just want to lift it enough to pull the oil pan and access the oil pump.
Old Jan 11, 2010 | 07:54 PM
klrz28's Avatar
Thats how I did it, 2 grade 8 bolts.
Old Jan 12, 2010 | 02:52 PM
RallyBoy1's Avatar
Do I need the remove the transmission crossmember to lift the engine a few inches?
Old Jan 13, 2010 | 10:58 AM
RallyBoy1's Avatar
Does anyone have any pictures of the lift points in order for me to change my oil pump pickup? Please help!!!!!!
Old Jan 13, 2010 | 11:29 AM
Z28SORR's Avatar
I think your trying to hard!
Any bolts that go into the heads or block will work. You could even put a strap under the intake manifold and lift it there. Your only lifting it a couple of inches. I've used a block of wood under the harmonic balancer and a hydraulic jack, worked fine. I don't think you need to "remove" the trans. cross member but I would loosen the trans. mount bolt, or remove it, to lessen the tension on it. You may have to remove the exhaust from the manifolds also.
jer4251
Sep 21, 2020 09:42 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
