Need quick answer! 918 springs...
Old Mar 19, 2005 | 11:46 AM
madhatter's Avatar
OK got the 918 springs and titanium retainers. What locks do I need? Also, I have heard mixed answers on the spring seats. Some say I need new ones and others say that stock will work fine. Help???
-Sean
Old Mar 19, 2005 | 11:58 AM
dirtybird96's Avatar
Re: Need quick answer! 918 springs...
I have them on the stock seats and they work fine. I can't remember the part number for the locks.
Old Mar 19, 2005 | 12:12 PM
truedualws6's Avatar
If you have the 794-16 titanium retainers you can use the
611-16 locks (standard), or the 614-16 locks (+.050). It
just depends on the installed height you are looking for.
The seats are 4705-16 and are .062" thick if you don't want
to use the stockers. Stock seats are about .040" thick.
You should check your installed height with your combination
to make sure things are OK.
Old Mar 19, 2005 | 12:25 PM
madhatter's Avatar
Well I am using stock valves, so should I go with the 614-16?
Old Mar 19, 2005 | 03:00 PM
SStrokerAce's Avatar
Most likely they will get you to the correct installed height.
Bret
Old Mar 19, 2005 | 03:20 PM
madhatter's Avatar
Bret
Correct installed height with stock seats or the other ones?
Old Mar 20, 2005 | 07:45 AM
Both
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
