Need part number for broken air injection pipe
Old Apr 17, 2009 | 10:05 AM
Dave Holland's Avatar
Thanks for the diagram shoebox!
This is on a 97SS.
I have a break in the air injection system where parts 11 & 15 in this diagram join. This is on the driver's side. It happened on the way to work this morning, so all I've had time to do is run to Pepboys & get some high temp tape & a couple of clamps to band-aid it for the trip home. Taking a quick glance, it appears the check valve threads onto the pipe, which means I'll need a new pipe & maybe a new valve if I can't get the broken stub out of the valve. Does anyone have the part number for the pipe? Thanks to shoebox, I've already got the valve p/n, 22048212.
Thanks.
-Dave
Old Apr 17, 2009 | 03:18 PM
GM PART # 12552898 for the pipe. I thnk the valve has changed to GM PART # 22040805.
On 96-97s there is also a fitting between the pipe and the exhaust manifold. That is GM PART # 12552329 if you need it.
Old Apr 18, 2009 | 12:05 AM
93FIRETURD's Avatar
i have a valve you can have for the price of shipping but it might not be worth it pm me if you want it though
Old Apr 20, 2009 | 11:07 AM
Thanks for the part numbers.
Old Feb 11, 2022 | 11:33 AM
Rwhurd's Avatar
Re: Need part number for broken air injection pipe
Originally Posted by shoebox
gm part # 12552898 for the pipe. I thnk the valve has changed to gm part # 22040805.
On 96-97s there is also a fitting between the pipe and the exhaust manifold. That is gm part # 12552329 if you need it.
im looking for ths part number 12552329.
Do you have one??
Old Feb 11, 2022 | 03:45 PM
Do you have one??
I don't. You may have to find it at a salvage yard. It looks to be discontinued.
HectorM52
Jul 30, 2017 11:46 AM
ro2207
Dec 1, 2014 01:02 AM
Jul 4, 2005 05:00 PM
CobraEatr
Jul 22, 2002 09:49 AM
