Lonnies dual pump set up
Old Feb 13, 2022 | 10:52 PM
CamaroSS30thAnn's Avatar
Anyone use lonnies dual pump set up? Install seems straight forward other than the engine bay procedure. I understand you have to modify the fuel rail. But I'm I'm getting conflicting opinions..
The kit seems to come with enough parts to run the new lines where you have 1 8 an line to the rail and 1 6an line out of the rail to the regulator. Ran in the same manner as the stock system.
Others are telling me to tee the back two and the front two. Back two are feed, front is return.
now i see how the second description works but I believe the kit is made to run as my first description
Is anyone familiar with this?
Thank you
Kevin Blown 95 TA
16
Apr 2, 2008 10:24 PM
blown69nova
Jun 27, 2007 06:12 PM
Miles-
May 6, 2005 03:40 PM
385LT1
May 19, 2003 06:24 AM
red
N2O Tech
Nov 16, 2002 05:47 PM
