Need INFO on convering my LT1 to carb
Old Nov 21, 2006 | 09:01 PM
Mikes 1994 z28's Avatar
Tired of efi and want something new. Anyone do this? Can I get the 4l60e to become stand alone. I know there are kits out there to convert the Ls1 to carb but are there kits to convert the LT1
Old Nov 21, 2006 | 09:11 PM
Gun5's Avatar
why would u want todo this?? get ur stuff ported and get a bigger tb... LT1's are cool dont give up on us
Old Nov 21, 2006 | 09:15 PM
GMRL's Avatar
Well, youll need this:
http://www.sdpc2000.com/catalog/738/...e-SB-Chevy.htm
And one of these:
http://www.sdpc2000.com/catalog/923/products/1203/SB-BB-High-Performance-HEI-Distributor.htm
You can get some tape that goes around the balancer to show timing in degrees, plus some kind of pointer so you can set the timing.
Also a regulator to reduce the fuel pressure to carb levels, Im not realy sure if it can be done with the factory fuel system, maybe a TBI system since it works with pressure similar to a carb.
What are you going to put this in? I realy dont think you can get the carb to fit under the cowl of a 4th gen without serious modifications.
Old Nov 22, 2006 | 09:52 AM
mdacton's Avatar
i looked into it before and it will cost you more to do it and get it right than massaging the lt1 a little
InfernalVortex
Jan 17, 2015 09:35 AM
Not Dave
Dec 11, 2014 06:32 PM
bernie1951
Dec 10, 2014 10:03 AM
Dusty98ta
Aug 14, 2002 04:25 PM
