need help wiring
need help wiring
ive been working on puttting an lt1 and t56 set up in my buddies 72 chevy truck and i need a little help with wiring. i need to know what connectors at the pcm are neccessary for the engine to run. im trying to eliminate as many wires as possible to clean it up. if someone can point me towards a write up would be great.
You don't say what year LT1, but my Tech Page has 95-97 PCM pinouts and such that you can look at. Basically, you need to supply all power and ground connections to the PCM and whatever sensors (some are necessary, some emssion items can be programmed out) that will remain functional.
i would appreciate it my e-mail is arodgers07@aol.com thanks
surreybrad
Apr 22, 2015 06:40 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
