Need Help!!: will my car run if......
Old 06-08-2005, 03:59 PM
speedracer69's Avatar
i have a 1994 Camaro with a stock ecu..
i just got done doing a 383ci with ported heads and 2.02's and 1.60's
CC306 and 1.6rr's
g2 intake and mass air....
42lbs with aftermarket FPR..
Hooker long tubes..
will it run on a stock computer settings? and i heard that with 42lbs that it will flood the rings?!?!?!?
thanks for your help
speedracer69 is offline
Old 06-08-2005, 04:02 PM
med_reject's Avatar
Re: Need Help!!: will my car run if......
you can run it with 24lb injectors until you get your computer reprogrammed. it will run crappy but it will be ok. I would not do WOT runs though, risk of leaning out.
If your computer thinks you ahve 24s and you are running 42s......
med_reject is offline
Old 06-08-2005, 04:08 PM
......................... (what)????
will damage happend?
Old 06-08-2005, 05:15 PM
lt11997's Avatar
If I was you I would get a mail tune before you drive it. After that I would try to get it dyno tuned.
lt11997 is offline
Old 06-08-2005, 05:35 PM
blind527's Avatar
Why would you get a mail tune then get a dyno tune? That's over 100 bucks just on the mail order tune.
blind527 is offline
Old 06-08-2005, 05:44 PM
lt11997's Avatar
I would want to get a dyno tune eventually, maybe not right away but the dyno tune would be able to get some more ponies out of your car.
The closest dyno tune I have is 2 hours away, there is no way I would drive my car that far without any kind of tune with his mods(assuming you don't have a way to trailer it).
lt11997 is offline
Old 06-08-2005, 05:57 PM
closes dyno is about 4 hours away.......
i just want to know if it will run at all with it the way it is
Old 06-08-2005, 06:14 PM
Alvin@pcmforless.com's Avatar
With a setup like that a Mail order tune will do perfect. The mass air LT1's are so predictable when it comes to tuning and particular mods.
one suggestion though, keep the stock MAF and go with 30lbs SVO's.
Alvin@pcmforless.com is offline
Old 06-08-2005, 06:24 PM
i built the motor for the bottle.............
thats why there is some much stuff!
Old 06-08-2005, 06:31 PM
1racerdude's Avatar
To break it in before wringing the snot out of it on the dyno,and to make it not wash the rings out of it.
Nobody said racing was cheep.
1racerdude is offline
Old 06-08-2005, 06:38 PM
this ring wash out thing....... what is it??
so i should do the 99.00 tuning untill the dyno day comes?
Old 06-08-2005, 06:43 PM
1racerdude's Avatar
Yes on the tune.
Ring wash is ya put so much fuel in the cyl's that the rings don't seal or seat from the gas,and no lube. If ya have molly rings they will slick out the cyl walls and never seat.
Old 06-10-2005, 11:33 AM
sounds like i'm going to do that
cmdeshon
12-27-2014 10:06 AM
ro2207
12-04-2014 06:18 PM
USAirman93
11-24-2014 03:37 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Brent94Z
03-21-2002 04:44 PM
Quick Reply: Need Help!!: will my car run if......
