Need Help!!: will my car run if......
i have a 1994 Camaro with a stock ecu..
i just got done doing a 383ci with ported heads and 2.02's and 1.60's CC306 and 1.6rr's g2 intake and mass air.... 42lbs with aftermarket FPR.. Hooker long tubes.. will it run on a stock computer settings? and i heard that with 42lbs that it will flood the rings?!?!?!? thanks for your help |
Re: Need Help!!: will my car run if......
you can run it with 24lb injectors until you get your computer reprogrammed. it will run crappy but it will be ok. I would not do WOT runs though, risk of leaning out.
If your computer thinks you ahve 24s and you are running 42s...... |
......................... (what)????
will damage happend? |
If I was you I would get a mail tune before you drive it. After that I would try to get it dyno tuned.
Why would you get a mail tune then get a dyno tune? That's over 100 bucks just on the mail order tune.
The closest dyno tune I have is 2 hours away, there is no way I would drive my car that far without any kind of tune with his mods(assuming you don't have a way to trailer it). |
closes dyno is about 4 hours away.......
i just want to know if it will run at all with it the way it is |
With a setup like that a Mail order tune will do perfect. The mass air LT1's are so predictable when it comes to tuning and particular mods.
one suggestion though, keep the stock MAF and go with 30lbs SVO's. |
i built the motor for the bottle.............
thats why there is some much stuff! |
To break it in before wringing the snot out of it on the dyno,and to make it not wash the rings out of it. Nobody said racing was cheep. |
this ring wash out thing....... what is it??
so i should do the 99.00 tuning untill the dyno day comes? |
so i should do the 99.00 tuning untill the dyno day comes? Ring wash is ya put so much fuel in the cyl's that the rings don't seal or seat from the gas,and no lube. If ya have molly rings they will slick out the cyl walls and never seat. |
sounds like i'm going to do that
