Need help on what noise this is
Old Apr 7, 2026 | 03:53 AM
TheFonz's Avatar
Just got my car back from the shop after getting a new clutch and I got this noise out of no where. Initially I thought it was valvetrain so changed lifters rockers, and pushrods still didn’t fix the noise. Could it be rod knock?
File Type: mov
File Type: mov
Old Apr 7, 2026 | 10:03 AM
irocbsa's Avatar
Re: Need help on what noise this is
Seeing that a new clutch was just put in I'm thinking that something in that assembly is making contact with something it isn't supposed to.
Old Apr 23, 2026 | 04:00 AM
ACE1252's Avatar
Get the car up on ramps and see if you can locate where the noise is loudest with a mechanics stethoscope. It might be something related to the clutch install, but I would not run it much until you can isolate where it's coming from.
What is your oil pressure showing at idle?
Old Apr 29, 2026 | 11:27 AM
Dtimekw's Avatar
Does the noise change when you push the clutch in? The second video sounds like a header leak at the flange. Is the noise consistent or erratic?
z275plus
Dec 30, 2006 11:21 PM
81ls1_z28
Sep 12, 2006 11:34 PM
96LT1TX
Oct 17, 2005 06:30 PM
96LT1TX
Oct 4, 2005 10:03 AM
