need help w/my throttle body.
Old Mar 22, 2006 | 09:35 PM
94blk-lt1's Avatar
i have an lt1 engine and its full of carbon! my camaro's idle is like at 2000!! can someone please help me? i need to know how to clean out the throttle body and the fuel injectors. it is full of carbon! i also have an air leak in the bellow....but i order that already. if someone could please help me...i need to know how to do it and what to use...stuff like that. i am new to all this....my first camaro...help plz!!! thanks.
Old Mar 22, 2006 | 10:12 PM
StephenDeli22's Avatar
Re: need help w/my throttle body.
I had a similar problem with mine. My intakr elbow had a severe rip right where it slides on to the throttle body. The throttle body was black inside. I used some carb cleaner and sprayed it liberally. Then opened the throttle blades and sprayed again. Fix the bellow or this will just keep happening.
For injectors, get some of that injector cleaner to put into your gas tank.
Old Mar 22, 2006 | 10:37 PM
Buttercup's Avatar
A little carbon is normal and won't hurt a thing. Not a bad idea to clean it up if you've got it off though. Some carb cleaner will do wonders. What's more sensitive to carbon buildup is the IAC circuit. I would recommend removing the IAC pintle assembly and cleaning it seperately so you don't drown it in cleaner.
As for the injectors, if they are stock they are a "self cleaning" ball type if memory serves me correctly (Multec?). They aren't sensitive to buildup like the pintle style. I don't believe the cleaner in the gas tank is all that effective anyway. If you really want to clean your injectors you need to connect the high pressure stuff right to the fuel rail or even better yet remove them and have them sonically cleaned. Honestly though, as long as you run good quality gasoline there isn't likely to be any problems with "dirty" injectors.
Old Mar 22, 2006 | 11:02 PM
Evil Eric's Avatar
Carb and Choke cleaner will strip that to the metal with a few sparys. Take it off the car first though or you'll blow smoke like a steam locomotive. I recommend B-12 chem tool spray.
Old Mar 23, 2006 | 01:56 PM
94blk-lt1's Avatar
if i do clean out the throttle body will that help to lower down the high idle??
Old Mar 23, 2006 | 02:00 PM
TraceZ's Avatar
Remove the TB and get a gasket kit for it. remove the IAS and the TPS. Removing the coolant/IAS housing from the bottom helps make it easier to clean too. Also, carefully clean the pintle on the IAS. Here are some pictures.
Old Mar 23, 2006 | 02:08 PM
94blk-lt1's Avatar
that will lower the idle right?? thanks for all the pics tracez.....it helps alot. is it hard to do though cuz i havent really worked on a car before...other than little things like an oil change or tire change.
Old Mar 23, 2006 | 02:46 PM
TraceZ's Avatar
I'd say it is skill level 3 on a scale of 1 to 10. Easier than a brake job.
Go get a gasket set first. There will be 3 gaskets. You can re-use the little orange gasket behind the TPS.
Also get a tooth brush, Simple Green and Gumout. Some rags, and you are ready to clean.
If cleaning the TB does not fix the problem, it could also be a bad IAS or a vacuum leak.
Now would be a good time to do a TB coolant bypass if you have not already done it.
Old Mar 23, 2006 | 03:01 PM
94blk-lt1's Avatar
what is a throttle body coolant bypass?? how would i do that? and on cleaning the throttle body, i can use a carb cleaner right??
Old Mar 23, 2006 | 03:30 PM
TraceZ's Avatar
A TB Bypass is when you take the two coolant lines that go to the TB and connect them directly to eachother, bypassing the TB. This helps keep the TB cooler, for better performance and it also makes it easier to work on in the future. It's worth about 7 horsepower. All you need to do it is a nylon hose connector and two hose clamps found at any auto parts store for under $5.
Yes, you can use gumout on the TB. Do not soak the 2 electronic sensors. Clean the pintle on the IAS carefully with a toothbrush and gumout, but do not soak the entire sensor.
Old Mar 23, 2006 | 03:34 PM
94blk-lt1's Avatar
hey, can you email me at g7rocky7@aol.com and explain in detail all this for me plz. thank you.
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
surreybrad
Sep 29, 2015 09:00 PM
KYWes
Sep 26, 2015 08:49 AM
