need help with valve locks
Old Mar 28, 2008 | 09:55 PM
nader454's Avatar
Ok,
I'm installing a cam, and replacing springs locks and retainers. After checking the installed height, I was putting the spring on the last f****** valve, when the compressor slipped.
It wedged one lock on the valve before I got the other one on. Now compressing the spring takes the retainer with it. I have used both styles of spring compressor. I tried rapping the retainer, digging it out, putting air in the cylinder, letting air out. Nothing works.
I hope some one has been down this frustrating path with a solution other than pulling the head. Actually, I don't know what to do different if the head was off. Thanks for any suggestions.
Old Mar 28, 2008 | 10:08 PM
dangalla's Avatar
have you tried to compress the spring and pull out the lock with a pair of needle nose pliers
Old Mar 28, 2008 | 10:21 PM
nader454's Avatar
10-4, like a millon times, its recessed a little, I think it's partially in the grove of the valve, maybe too far down...thanks anyway.
Old Mar 29, 2008 | 08:47 AM
9formula4's Avatar
try compressing the spring and tapping the compressor with a hammer. then wiggle it back and forth and you should be good.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
Jun 15, 2015 09:51 PM
Roadie
Feb 16, 2015 10:34 AM
