need help with some parts numbers
for my 93 z28,im installing lts soon and could use some help with the parts I need
gaskets- copper are the best??
arp header bolts?
nkg spark plugs?
msd wires
o2 sensor
and everything else I have covered,I know this subject is beaten to death but im new to the performance thing and I dont want to order the wrong parts,thanks guys
arp header bolts?
nkg spark plugs?
msd wires
o2 sensor
For NGK spark plugs get # TR55.
For an 02 sensor, get a DENSO one(s); they are virtually lead proof so that they are even compatible with leaded race gas, not to mention they cost about half what AC Delco's cost.
Cant remember the part number, but they no longer list them for V8/LT1 Z28's...get the ones for the same year corvette as your Z28; they are EXACTLY the same.
Yes, copper header/exhaust manifold gaskets are the best....if they are copper, virtually any brand will do....I used the ones that came with my MAC headers.
Regarding copper head gaskets, it is a mixed result. Some people on this board swear by them others say they leak on a daily driver.
If you prep the copper head gaskets with Hylomar then I've heard only good stories. Hylomar stays tacky and doesn't dry so it is great for expansion & contraction.
thanks for the info, should I just use the gaskets that come with the headers then?
Copper header gaskets will not leak coolant
and they will be fine on your lt install The gaskets that are supplied with most brands of headers are usually junk.
Brandon Wittmer
Dec 7, 2014 12:15 PM
