Poly-Locks keep coming loose
Old Dec 29, 2006 | 09:41 PM
bingo's Avatar
Is there some trick to tightening these? I have used these on five other engines without problems but, this time is different. I have tightened the set screw down so tight the allen wrench almost bends. They keep working loose. I read the article on shoebox's site and I have tried them all. What am I missing?
Old Dec 29, 2006 | 10:14 PM
matLT1's Avatar
I turn the adjusting nut and set screw at the same time for the last 1/8 turn of adjustment. Hasn't given me any troubles.
Old Dec 29, 2006 | 11:50 PM
bhop42's Avatar
Make sure you are tightening the polylock on the flat of the rocker arm.
Old Dec 30, 2006 | 10:13 AM
bingo's Avatar
I already checked that but, I will check again today. I love my new engine but, these rockers are killing me.
Old Dec 30, 2006 | 10:18 AM
Wild1's Avatar
I agree with turning both as a jam-nut technique for the final twist. However, loctite BLUE is very easy to remove and will lock in the poly lock. Do not use red or it will be a pain to remove in the future.
Old Dec 30, 2006 | 10:33 AM
96capricemgr's Avatar
The studs do have a flat top to them right????
I agree on turning the nut and set screw together the last little bit.
Old Dec 30, 2006 | 10:55 AM
wrd1972's Avatar
Get either I high quality allen wrench or a allen tipped socket so you can use a wratchet. This will give you more power.
I have never had a problem, every time I remove mine they CRACK loose which usually results in bloody knuckles. There aint no damn way mine could ever loosen.
Old Dec 30, 2006 | 03:57 PM
bingo's Avatar
I retightened them earlier. A couple were working loose. This time if they come loose it will be a miracle. I put a gorilla tightening on them.
Victor Lamb
Aug 26, 2017 02:52 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
MJ_Z28
Aug 7, 2002 07:15 PM
