need help with shortblock
Old Jun 3, 2005 | 05:00 PM
  #31
93camaroLT1's Avatar
Re: need help with shortblock
Originally Posted by 1racerdude
Oil pump is automatic, don't put it in and ruin a rebuild trying to save a dollar and you will kick your own a**. Not to mention that it's gonna cost a bunch more the second time-- lot more than a pump,by at least 1500-2000 dollars Soooo a $40.00 pump doesn't look so bad,does it.
Rods- CB663H
Mains- MS909H
Cam-SH1349S
I use these brgs in all my customer motors and my own.
ARP pump drive#- ARP-134-7901
If it is stock ya got a 4" bore depending who's brand ya get on the part number. NO MOLLY
* Package includes the pickup factory welded to the oil pump for a simple, bolt-on installation
* High-volume Moroso oil pump provides up to 25% more oil to provide superior lubrication at higher engine speeds
* Moroso Oil Pump Pickups are precision bent for precise fit; wire mesh screen traps debris without restricting flow
* Pickup orientation ensures optimum 1/4" clearance from bottom of pan, eliminating the need to measure, align or weld
* Orientation also ensures that the pickup is placed "where the oil is" under demanding racing and street performance conditions
* Includes pump mounting stud, nut, and washer
* Use with heavy-duty Moroso Oil Pump Shaft No. 22070 for SBC and No. 22080 for BBC, or other similar hardened steel shafts with steel sleeves
No. Description/Application
22125 Oil Pump and Pickup Package, Small Block Chevy, 8-1/4" depth pan, standard-volume pump
Fits Moroso Pan Nos. 19510, 19520, 20180, 20181, 20182, 20190, 20191, 20200, 20205, 20230, 21010, 21015,
22135 Oil Pump and Pickup Package, Small Block Chevy, 8-1/4" depth pan, high-volume pump
22145 Oil Pump and Pickup Package Small Block Chevy, stock 7 1/2" pan depth, high-volume pump. Fits Stock GM Pans
Choose what pan ya have and get the part #
couple more questions...
Do I need to get the ARP pump driveshaft, part # ARP-134-7901 AND the moroso intermiadiate shaft part number 22070 for the moroso 22145 oil pump and pickup assembly (for stock GM pan)??
Which is the correct rings to get out of the following?
-SLP-E-251X
-SLP-E-377X
EDIT: actually now that I look into it, neither of those are file to fit... No file to fit rings show up on summit when I search for sealed power iron rings for a 4.0" bore... What is the part # for sealed power or hastings file to fit rings??
Old Jun 3, 2005 | 05:19 PM
  #32
1racerdude's Avatar
-SLP-E-251X
-SLP-E-377X
Don't know off hand. Call your local dealer and find out.Depends on the brand.
The Moroso kit comes with the correct shaft and that's all ya need.
jackpawt883
Jul 31, 2015 08:15 AM
Kimchee & Rice
Jun 29, 2003 07:21 PM
pillagenburn
May 1, 2003 12:20 AM
Deadcarny
Feb 7, 2003 11:48 PM
