Need Help Removing Slip Fit Tube on Header..
Old Dec 30, 2003 | 10:03 PM
Brandon 95 Z28's Avatar
Red face Need Help Removing Slip Fit Tube on Header..
Hey,
I am having serious trouble removing the slip fit tube on the #1 primary on my driverside Mac Header. I pulled the heads and intake, and had to work around the damn header to get the head out. The header is completely unbolted, the clamp holding the slip fit is completely undone and off the mating point, and I cant get the slip fit out at all. I was able to twist it a little bit, but I cant really twist it back and forth to the point where it would come out. Any ideas or advice to get it off???
Thanks,
Brandon
Old Dec 31, 2003 | 08:48 AM
93transam1234's Avatar
spray
i guess just spray PB blaster on it and keep twisting! but some muscle into it man!
Shhot i would try to keep them together after trying to fix my slip fit leak.....
Old Dec 31, 2003 | 09:02 AM
stereomandan's Avatar
It may also help to heat the bottom of the slip joint a little to make it expand. Try to keep the top portion cool. It might slip off easier that way.
Dan
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
ANDYZ28
Dec 29, 2014 09:13 PM
