Need help with Racetronix LT1 fuel pump kit 97 Z28
Old Apr 24, 2011 | 01:35 AM
Henson071's Avatar
I got the harness/relay in, the pump is in the bucket, the original pump connector is obselete now, but where do I place that damn ground? Its the push type ground, like it gets inserted somewhere. I am lost and the pump is going in tomorrow, please help.
Danny
Old Apr 24, 2011 | 08:03 AM
Re: Need help with Racetronix LT1 fuel pump kit 97 Z28
I posted this on your cross-post on the "Fuel and Ignition" forum. Normally we discourage cross-posting, but you appear to be in panic mode.
I just looked at a spare, stock fuel pump support assembly I had on the shelf in the garage. The in-tank wiring has a connector that plugs into the top/cover part of the support assembly. There are 3 wires attached to that connector. One is purple and has a narrow (~1/8") female spade lug connector on it. One is green, and connects to a small female 2-pin connector. The third wire is black, and has a wide (~1/4") female spade lug connector. Black is typically the ground connection.
I don't have the wiring diagram in front of me, but I suspect that the 2-pin connector (which also has a black wire that connects to the 1/4" spade connector) is for the level sending unit, the purple wire is 12V to the pump, and the black wire is ground for both the pump and the level sending unit.
Old Apr 24, 2011 | 09:49 PM
Couldn't have been very important. Signed off at 2:43am, and never came back to look at the answer.
Locking multi-forum post.
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
Jul 4, 2005 05:00 PM
Skull Leader
Aug 10, 2002 11:01 AM
