Need help quick! Lifting ac out of the way
Need help quick! Lifting power steering out of the way
I've just about got the second head off, there is just one bolt holding the accesory mounting bracket left to get off, but the power steering pulley thing is in the way. I know you are supposed to "lift" it out of the way, but I can't seems to do it. Do you need to disconnect the two lines going into it?
Re: Need help quick! Lifting ac out of the way
You have to take the lines off to get the power steering pump off. Like shoebox said, make sure the pump is unbolted first. You can do this by rotating the pulley and sticking the socket through the hole to get access to the bolts. I think they are 10mm and you will need an extension. Not insulting your intelligence here, just making sure you did those things first.
I misunderstood what you were saying. Fluid shouldn't shoot everywhere. Some will leak out the hoses when you take them off but it won't spray all over the place. Just keep some rags under it and you'll be fine.
You shouldn't have to take ps completely off, just unbolt it and it will move enough.
and you should definately not need to take the ac completely off either. when we did mine we left the metal tubing connected and just lifted the drivers side up and there was room to remove the cam, if thats what you're trying to do.
Just got it off. Now I wish I hadn't siphoned it out after seeing how little really would have come out. Oh well, just go buy some more I guess.
oh, and WHOOO HOOO!!!!! Both heads are finally off!!!!!!!!!!!!!!!!!!!!
now I just gotta get the damn hub off of there.
68camaroboltz
Oct 5, 2015 11:56 PM
NewsBot
Sep 14, 2015 09:20 AM
