Fuel Pump install guide
Old Mar 22, 2005 | 09:42 AM
Kredz28's Avatar
Was wondering if anyone has a fuel pump install guide to help me install my holley 255 lph in tank pump into my 93 z28 camaro. I will not be doing the access door mod, i will be dropping the tank. Please HELP!
Old Mar 22, 2005 | 09:46 AM
1-bad-z28's Avatar
Re: Fuel Pump install guide
I would definetly recommend the trap door method. It has no side effects and you can't see it when it's done and it makes it a hell of a lot easier. Sorry no guide though.
Old Mar 22, 2005 | 09:50 AM
Kredz28's Avatar
yea ive heard its a lot easier, but i wanted to compare it to dropping the tank to see how bad it is. I have a guide to the access door mod, and i will give it another look. Is there anyproblems with fuel smell inside car with the mod? Vibrations?
Old Mar 22, 2005 | 09:54 AM
1-bad-z28's Avatar
When you make your "trap door" you just seal it real good. No smell. Can't see it from the top or the bottom. And if you ever need to get back in there, it is already done. Some cars come from the factory with these trap doors. If you want to drop the tank, everything on the rear of the car has to come off, the rear end, drive shaft, suspension, and tank. Not worth the hassle in my opinion.
Old Mar 22, 2005 | 10:05 AM
Kredz28's Avatar
ive heard all you have to do is get the car no a lift, jack frame up, let rearend hang, remove catback, take straps off tank and pull the pump. If it came down to removing the rearend, i wouldnt do it...lol
Old Mar 22, 2005 | 10:24 AM
1-bad-z28's Avatar
I don't think i have ever heard of somebody doing it without dropping the rear end
Old Mar 23, 2005 | 11:45 AM
Kredz28's Avatar
any one else know of an install guide to drop tank and swap pumps I need help immediatley!!! Please help.
Old Mar 23, 2005 | 03:40 PM
Kredz28's Avatar
or any install intructions for the access door install?
Old Mar 23, 2005 | 03:54 PM
KPZ-28's Avatar
http://www.bfranker.badz28.com/fbody/fuelpump.htm
Old Mar 23, 2005 | 03:57 PM
FuryZ28's Avatar
I've yet to install mine either. I'll either do the trap door thing, or I'll wait until I have the $$ to swap in a 12-bolt...
Old Mar 24, 2005 | 11:04 AM
Kredz28's Avatar
i was actually debating getting a 12 bolt too just so i dont have to cut the car to swap pumps!
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
LT4Ryan
Jul 29, 2002 08:38 PM
