Need help quick!
Old Apr 25, 2003 | 07:05 PM
hsyr's Avatar
Need help quick!
Ok. I blew a spring out of my spec stage III awhile ago. I got a new disc, installed everything, and when I goto drive I cannot shift into gear if the clutch pedal is pushed all the way to the floor. But If I let the clutch be about 1" from the floor I can put it into gear. I can drive the car if I drive like that all the time. Now my question, why is it that I have to push the clutch pedal all the way but 1" to get it into gear and shift while driving? Also, when I'm in gear at a stop light (1st or any) and the pedal is pushed all the way to the floor the clutch tries to grab, but when I let off 1" it stops and acts normal. I replaced the master/slave and I'm running out of I ideas! In 20minutes I'm going to go pull the tranny, any suggestions?
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
