Need help installing dual cutouts
Old Jan 15, 2006 | 10:42 AM
Jeremy95TA's Avatar
First off, I know the pro's and con's about dual cutouts and I have decided on dual cutouts. So please don't stray the topic with 1 cutout vs. 2 cutouts. That said...
I have Pacesetter LT's and a Pacesetter Y-pipe. Neither have been installed on the car yet. I also bought two 3" cutouts from Summit. I want to install them, but I'm not certain on the best way to install them. Should I chop up the y-pipe and weld the cutouts in, or should I put the cutouts on the headers and then the y-pipe after the cutouts?
I tried searching for this information, but I didn't find a lot on the subject. I also wanted to see pictures of other dual cutout LT1's. I have several friends with LS1's running dual cutouts, but I don't know how different they are from the LT1's. I would greatly appreciate any pictures and advice on this. Thanks.
Old Jan 15, 2006 | 11:20 AM
96flame's Avatar
Re: Need help installing dual cutouts
The cutout on the right won't be a problem at all. Stick it on the end of the header and cut off however much of the y-pipe you need to. The left one on the other hand could be interesting. The floor has a brace which will be in the way. The y-pipe has a flat spot for this. If you put the cutout after that point you'll likely run into the bend. You'll need someone to fab it up for you.
Old Jan 15, 2006 | 05:17 PM
Jeremy95TA's Avatar
I figured something along those lines, but can I still use the Pacesetter Y-pipe and have it modified, or should I just go with something completly custom. I don't have a lot of money, but I want something effective.
Old Jan 15, 2006 | 05:36 PM
96flame's Avatar
I would think its cheaper to use the pacesetter y-pipe and cut into it. Usually labour is worth more than pipe.
Nov 18, 2023 07:21 PM
Jan 23, 2015 01:13 PM
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
turbo_Z
Aug 19, 2002 10:50 PM
