need help with idiot lights and starting
Old Aug 14, 2003 | 12:04 AM
limige's Avatar
Exclamation need help with idiot lights and starting
i ripped the trans out, put a new clutch in and white faced gauges, did a new rear without abs and ditched the whole abs unit by installing a pp. valve.
my low oil sensor is disconnected as well as the cags, and reverse lockout silinoid.
since then my low oil light is on (duh), abs light (duh again) and check engine.
i can't flash the trouble codes, and the check engine doesn't come on immediantly it takes a few minutes.
and....the car won't start most of the time after it has cooled off until the second or third try.
could it just be dirty o2's?
is it something disconnected messing with the cpu?
Old Aug 14, 2003 | 02:58 AM
limige's Avatar
well i just seafoamed it, burned it off, shut the car down, gassed up and the check engine still came on. i'll run another tomorrow and one in the tank to try and get it cleaned out. if this don't work i'm replacing the o2's, plugs and wires.
any other thoughts.
eazyZ
Mar 1, 2015 07:12 AM
squarehead
Jan 15, 2015 07:02 PM
97z28k&N
Jan 9, 2015 04:58 AM
blac94Z
Dec 2, 2014 12:09 PM
cristian1311
Nov 23, 2014 02:22 PM
