Need help identifying Lunati Camshaft.
I have a Lunati cam but im not sure the exact specs. On the bottom of the cam it says: "95 up", "N4LP", "113",and "RRA1-224-234".
Ive searched on the internet but i cant find any information on this cam.
Thanks!!!
Thanks!!!
Re: Need help identifying Lunati Camshaft.
What is the 5 digit number on it?? Should start with a 5...
Otherwise, from the info you gave me, I would suspect the cam to have the long dowel pin, have a 113 LSA, and have a duration at .050 of 224 intake-234 exhaust. With the 5 digit number, I should be able to get you the lift.
Ryan
Ryan
it dosent seem to have any other printings on the cam. Where would it be other than on the end of the cam. and It kinda looks that when they stamped the LUNATI logo on it they may have covered up some numbers.
same old rich... some things never change.
To defend myself, i just unearthed it yesterday and THEY AREN'T OPEN! Ill call on monday if i get the time, but since there are so many knowlegdable individuals on this site i figured that asking wouldn't hurt.
Rich
its allright. I paid like 200 bucks for this cam used and lost the info on it. Ive had it sitting here for ever and now that my engine developed a rod knock im going to do a rebuild and use this cam. I just wanted to know the lift numbers so that i can match the valve springs and rockers to it.
If you have a micromometer or a set of calipers, just measure from the base circle to the peak of the lobes, multiply by the rocker ratio, and voila - the lift!
Rich
Rich
I did call Lunati today and they were able to get the specs for me.
Advertised Duration:279I/286E
Duration @ .050:224I/234E
Lift with 1.5RR: .489I/.479E
Thanks for the help guys
Catmaigne
Jul 14, 2015 05:17 PM
