Weird car symptom (what can it be)
Old Oct 25, 2004 | 10:48 AM
formula king's Avatar
okay first of all I want to say that my car has been running bad for awhile. Im thinking opti because the car has lost ALOT of performance, horrible gas mileage,boogs down, and the car sounds weaker...............
But the weird thing is that my car runs better whenever i have more than a half-tank of gas in...whenever it goes under that the car takes awhile to turn over to start and the car runs worse than it already does.
What could that mean
Old Oct 25, 2004 | 11:05 AM
crash4cyl's Avatar
Re: Weird car symptom (what can it be)
start checking the fuel system....filter to start. Then check out the FP and see if the pump is putting out what it should...45psi I believe. Those are the starting points...are there any codes??? Welcome to OBDI diagnostics!!! what fun!!!
Chris
Old Oct 25, 2004 | 07:36 PM
slopokrodrigez's Avatar
In the tank, above the fuel pump is a rubber hose that connects the pump to the hard line comming out of the tank. Yours has a hole in it.
jj71787
Dec 30, 2014 02:15 PM
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 12, 2014 10:51 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
