Need help on Hurst line lock install...
Old Dec 19, 2002 | 08:21 PM
csabatka1's Avatar
Not installing it yet, but wanting to make sure I know how to install it. I bought it used awhile back ago and it didn't come with instructions, and one of the lines broke during shipping, so I'm going to have to bend another one.
I think I know where the brake lines go, but want make sure. Also, where did everyone hook the power/ground lines up to?
One brake line goes to the ABS block in the frontmost (towards front bumper), and the other goes to the rear master cylinder line?
Old Dec 19, 2002 | 09:41 PM
Smokn '94 Z's Avatar
Lightbulb Re: Need help on Hurst line lock install...
I have mine grounded to a ground screw in my engine bay that I have all my aftermarket electrics on. ( Gauges,Linelock.....) You can also ground it to one of the screws you use for mounting the solinoid under the hood. As far as power I am going in the fuse panel on the side of the dash.
You are correct on the placement of the brake lines also. However I have to ask if you have the correct flare nuts to convert the lines. Our flare nuts are metric stock & cannot be reused. You will need the metric to standard fittings to use the standard nuts that come on new brake lines incase you didn't know this. I almost stripped my master cylinder threads & abs Threads. I think the fittings are (M11) Not sure though. I forgot. Good Luck.
Old Aug 29, 2003 | 04:59 PM
JohnsSS's Avatar
which one is the rear master cyl line? Mine has two lines comeing out the bumper side one above the other?
Old Aug 30, 2003 | 12:13 AM
The front brake line you want to cut into starts at the rear of the master cylinder, and runs to the front connection on the distribution block on the side of the ABS unit. The metric fittings are actually different sizes on each end of the line... I think Rob/Shobox has the correct sizes.
Line Lock photo #1
Photo #2
Photo #3
You can get pre-bent lines from Thunder Racing, or a complete install kit. You can't use the Hurst "universal install" kit, because of the metric fittings. You can make your own lines if you can find the fittings and make the "mushroom" style flare. My lines are home made, and I'm not really happy with the way they look. Work fine though.
Old Aug 31, 2003 | 01:55 PM
JohnsSS's Avatar
...so should i return the summit racing universal kit and buy the one from thunder racing, or should i try to find some metric connections(the summit kit came with a whole bag of different connections{and i got 2 of them for some reason}). Let me know what u think.
Old Aug 31, 2003 | 03:35 PM
I don't know what fittings they include in the Hurst kit. Check with Rob/Shoebox... he knows the correct GM fitting sizes for the master cylinder end, and the ABS end (for some reason, they are not the same size???).
The TR kit is also loaded with parts that some people don't want/need. It has the pre-bent lines, so that part is good. It includes a relay, which I think is good, because all my high current devices are wired through relays, but some people skip that step. The TR kit includes a wiring harness, but it assumes you want to have a "master" arm switch (doesn't turn the line lock on, just allows you to turn the power supply to the line lock button off, so you can't accidentally engage the line lock) and some other stuff. In my specific application, I had someone fab up the lines for me, and I wired the relay up the way I wanted it, with the kind of switch I found most useful for burnouts.... I actually didn't like the "trigger" switch that Hurst includes for the shift lever, because is tended to get jiggled when I banged the B&M ratchet shifter to get it into 2nd gear for the burnout. That's where you need to decide exactly how you plan to install it and wire it, before spending $100+ on the TR kit.
Old Sep 7, 2003 | 12:09 PM
chpmnsws6's Avatar
does anyone have it on an LS1 car that they can show me a picture!?! i need to hook it up but i wanna be 100% sure i'm right so i don't mess it up.
Old Sep 7, 2003 | 11:11 PM
You'll have a lot better chance of getting a response from someone with an LS1 if you post on "LS1 Tech".... not here on "LT1 Tech".
Old Sep 7, 2003 | 11:52 PM
There is a chart on the right hand side of this drawing that shows all the fitting sizes at what locations.
Fastbird93
Apr 9, 2016 07:01 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Pampered-Z
Apr 14, 2015 05:38 PM
rje
Sep 9, 2002 12:35 PM
