Need help fast...Alternator bracket replacement after header install
Old Dec 1, 2005 | 09:00 PM
wrd1972's Avatar
Got to the point of putting the alternator back on after installing headers and I have forgotton the sequence of parts on that lower bracket.
I have that stud looking thing with a hex in the middle of it, do I put that spacer on the stud and screw it into the head or do I have to install a new spacer the same thickness as the exhaust manifold flange.
Once all that stuff is on I guess that rod like bracket simply bolts on.
Any help here is greatly appreciated.
Thanx
Old Dec 2, 2005 | 12:12 AM
revtime's Avatar
Re: Need help fast...Alternator bracket replacement after header install
If your talking about the bracket that bolts to the exhaust manifold and bolts to the alternator.......you don,t need it. Throw it far away from you and screw a header bolt in that hole.
Old Dec 2, 2005 | 12:43 AM
Cmr0z28's Avatar
HectorM52
Jun 23, 2016 08:42 PM
Hurin
Dec 13, 2014 07:38 PM
thenewkid
Nov 27, 2014 09:41 AM
squarehead
Nov 21, 2014 08:02 PM
