Need Help Fast
Old Feb 22, 2003 | 12:40 PM
93ZM6Tally's Avatar
Need Help Fast
My car is in the driveway on jackstands and I can't get the wheels off of the car. I have all of the lug bolts removed but the wheel will not come off of the car. Am I missing something? I feel very stupid but I can't see whats holding the wheel on the car.
Old Feb 22, 2003 | 12:56 PM
Larnach's Avatar
You've taken off all of the lug NUTS and the wheels are not coming off?
Old Feb 22, 2003 | 01:00 PM
93ZM6Tally's Avatar
That's right and they feel like they are still on there solid. I can't see anything thats holding them on there. Any Ideas?
Old Feb 22, 2003 | 01:04 PM
Rodrigues's Avatar
Soak where the wheel connects to the hub with WD40 and just try pulling it off, it really shouldn't be that hard. If they havent been off in a long time then it could be hard to get them off. Try not to spray the disk brakes with any of the WD40 though. Might want to cover them with a garbage bag first.
Old Feb 22, 2003 | 11:52 PM
qwick_trip's Avatar
spray some wd40 or something on it and take a rubber mallot and tap the inter part of the rim and it should come off.
Old Feb 23, 2003 | 12:13 AM
Any progress? ( I bet you have them off by now, LOL!)
Where these non-stock wheels and were they front or back?
My guess it that you have late model wheels on the back and the inside of the wheel hubs were not relieved enough prior to putting them on and they are wedged on the axle hub.
Old Feb 23, 2003 | 10:38 AM
93ZM6Tally's Avatar
Gotem Off
Rob - you are correct I finally got them off and got the shocks and springs on. Put them back on with plenty of anti-seize, hopefully that will help. Used your instructions BTW for the shocks and springs. Thanks
Old Feb 24, 2003 | 08:29 AM
93ZM6Tally's Avatar
Rob, BTW what do me when you say that "the wheels aren't relieved enough". How would I do this?
Old Feb 24, 2003 | 09:05 AM
If you have late model wheels on the back, they usuall interfere with the axle hubs. They made the later model hub protrusion smaller and consequently the hole in the wheel smaller. So the hole in the center of the wheel needs to be opened up just a little to clear you older, larger hub. If you look on the back of the wheel, you can probably see where it is interfering. Sandpaper, Dremel or I even used a large half round file to dress mine down a little so it would clear. You will end up doing all four wheels if you rotate your tires. The fronts have no interference problem. You may even find that one or two of the wheels fit ok without any modification, because of wide manufacturing tolerances. The wheels are not centered by the hub, but by the lugs, so there is not a problem if the hole is not perfectly round. It does not take much removal anyway. Take a little off and keep trial fitting it until it goes on easily.
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
