Need Help Exhaust manifolds are cherry red
Old Nov 13, 2005 | 04:51 PM
wolfepack95's Avatar
Question Need Help Exhaust manifolds are cherry red
Hey Guys
Once again i need some help. Last night my z28 started running real bad and started loosing power the temp went up then it really lost power .I looked under the hood and sence it was dark i seen both exhaust manifolds cherry red. I just put new heads on the car 3 weeks ago and it been running fine but i did notice a smeel like gas at the back of the car. last night was the longest run i put on the car 200miles to nashville now this happened. Could it be the catalytic converter clogged up and could that be the gas smell also?
Thanks for any advise
Ron
Old Nov 13, 2005 | 05:01 PM
Makaveli's Avatar
Re: Need Help Exhaust manifolds are cherry red
sounds like a catalytic converter problem to me, only two reasons your manifolds would glow red would be a timing problem or a clogged cat, and the exhaust smell would lead me to think its the cat thats giving you trouble
Old Nov 13, 2005 | 05:33 PM
94zrag's Avatar
I'll second what he^ said, I had the same thing happen to me before. All it took was a long screwdriver and a hammer to clean the cat out and it ran fine after that.
Old Nov 14, 2005 | 07:43 PM
Question Re: Need Help Exhaust manifolds are cherry red
its offical the Catalytic converter is bad. Now they want 139 labor and 300 to cut the old one off and weld a new one on or 540 total for one that has the ypipies on it. What is the best thing to do ? what is the best brand?
Old Nov 14, 2005 | 08:21 PM
Makaveli's Avatar
you could get a 3" universal catco or carsound cat on ebay for like 60 bucks, and then have them weld it in there. i dont see any reason to drop 540 bucks on a cat install personally
Old Nov 14, 2005 | 10:37 PM
aarontracy's Avatar
forget paying for that!!! just unbolt the exhaust at the cat, get a metal bar like a crow bar, or sumthin and beat the insides of the cat out!
Old Nov 14, 2005 | 10:39 PM
jasons93z's Avatar
Have a shop put in an ORP, 40 bucks, plus about 7-10hp.
Old Nov 15, 2005 | 12:30 AM
69gto96z's Avatar
Just remove it and put in an 02 sim. Thats what I did when one of mine clogged.
Old Nov 15, 2005 | 07:59 AM
Makaveli's Avatar
single cat cant just use an o2 sim, thats only for dual cat cars with a second set of o2's after the cats. although i dont think it throws a code if the cat isnt there
Old Nov 15, 2005 | 10:05 AM
EKO's Avatar
EKO
Single cat cars only have 2 pre-cat O2's, one for each bank. Removing the cat has no effect on the operation of the engine, other than increased hydrocarbons and a few extra HP.
Old Nov 15, 2005 | 07:11 PM
thanks guys Im having the inside of the cat cleaned out. And your right i only have 2 o2s before the cat.
Old Nov 15, 2005 | 09:41 PM
69gto96z's Avatar
I thought OBD-1 cars had a single 02 behind the cat?
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
