Need help with exhaust manifold
Old Mar 26, 2007 | 08:18 PM
trickster2k4's Avatar
For the past month My exhaust manifold gasket has been getting destroyed because of a leak. Today I decided to replace it and found that the previous owner of the car must have taken the manifold off before. I figured this out because the back 2 bolts are broken off in the block. I replaced the gasket and tightened the bolts, so it sounds fine and it doesnt feel like anything is coming out. I was just wondering what I would need to do to get out the parts of the bolts that are broken inside? Both of the heads are missing. Thank you for any help.
Old Mar 27, 2007 | 08:46 AM
2000GTP's Avatar
It'll be pretty difficult to get those bolts out unless you pulled the heads. If they are the very back bolts, then it would be a good time to upgrade to headers as those bolts are not used.
69z-28
Jan 29, 2016 10:46 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
