???????=smoke
Old Mar 26, 2007 | 09:14 PM
BrokeMofugga's Avatar
???????=smoke
I have a strange oil leak somewhere?I mean ive never really seen any on the ground or anything.but sometimes after i get on it there will be smoke coming from under the hood.now i was thinking that it would be the valve cover gaskets leaking at the back of he engine bay because thats where the smokes seems to be coming from.so i already bought new gaskets for it.and i will be putting them on in a couple of days.so should i look for anything else it maybe?thanks in advance
Old Mar 26, 2007 | 09:16 PM
mdacton's Avatar
check the intake
Old Mar 26, 2007 | 09:41 PM
pattracing212's Avatar
i had a similar problem and i ended up being the oil sending unit. i don't know for sure though because i never seen it personally. it was seen and changed when it was getting a new trans....i only seen the symptoms, not the actual problem
Old Mar 27, 2007 | 08:49 AM
2000GTP's Avatar
The rear intake manifold oil leak is a very common problem.
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
alphaauto
Jul 26, 2015 04:40 PM
