Need Help Diagnosing Car from DataMaster Files
Old Nov 3, 2003 | 08:03 PM
ComputerNerd's Avatar
Just starting to try to see what's wrong with my Z28.
Here are four datamaster files
(2 sitting at an idle and 2 on the road).
If anyone could take a look and let me know anything they see that looks irregular it would be greatly appreciated...
Brief history on car:
1994 Z28, 355 /w hotcam kit, edelbrock headers, tuned computer(so I was told)
Car has very ruff idle, runs very rich, and has a pretty nasty stumble.
I've only had the car two weeks and I hate to just start throwing parts at it.
Here are the links to my datamaster files. Right click and save as...
idle1
idle2
run1
run2
Old Nov 3, 2003 | 09:21 PM
gb95zconv's Avatar
Your log shows you to be extreemly lean......the pcm is adding 20-25% more fuel across the board. Do you have a copy of your pcm file? Do you have Tunercat or lt1 Edit?
Old Nov 3, 2003 | 09:58 PM
I do have tunercat...
Here is my current .bin
Old Nov 3, 2003 | 11:45 PM
Man this forum moves fast...
ttt
Old Nov 4, 2003 | 06:53 AM
26 view and only one reply...
Anyone want to take a shot at this one?
Help would be greatly appreciated.
Thanks...
Old Nov 4, 2003 | 10:11 AM
Thanks...
You need to "export" the files and post them in ".csv" format. Unless you do that, only people with DataMaster can view them. I probably look at as many of these files as anyone, but I don't have DataMaster, so I can't help you with the ".uni" format.
Possible reason you aren't getting much help.
Old Nov 4, 2003 | 12:35 PM
Sorry about that... Here are the csv files...
idle1
idle2
run1
run2
Old Nov 4, 2003 | 05:02 PM
ttt
Old Nov 4, 2003 | 06:31 PM
turbo_Z's Avatar
main problem i see is your car keeps going from open loop to closed loop for no apparent reason and your engine temp sensor is either busted or it has a bad connection.
Old Nov 4, 2003 | 06:37 PM
turbo_Z's Avatar
it also appears you have a rather large vacuum leak since your idle vacuum is up around 17 inHG when it should be about 12-15. this would also explain why the BLMs are maxing out at 160.
LeftoverChinese
Jan 14, 2024 03:03 PM
NewsBot
Dec 28, 2014 06:20 PM
Queens94z28
Dec 20, 2014 09:11 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
