Need help! Debris in my oil!
Old Mar 27, 2006 | 05:37 PM
9c1ny's Avatar
Ok my oil level sensor (the one above the drain plug) was leaking bad so I decided to change it........
I drained the oil and put the plug back in and changed the filter........
Upon pulling the old one out I found that the float was loose on the shaft and that the backing plate that prevents it from sliding off was missing........
The plastic on the float looks brittle and a little disentergrated also......
I am assuming it (the backing piece) is in the pan......
It is maybe 65% the size of a dime and maybe 1/5th an inch thick......
I am assuming its plastic, it is on the replacement anyways.......
So what to do????
Is this thing big enough to cause major damage?
If I fill her back up and drain her should it come out???
What are my options????
I really dont want to pull the pan
Anyone experienced this?
Old Mar 27, 2006 | 10:57 PM
VegasZ's Avatar
Re: Need help! Debris in my oil!
Same thing happened to me. When I pulled my old oil sensor out the float fell off in the pan. I just left it in there. It has been 3 years and 20k miles since then and no problems.
Old Mar 28, 2006 | 02:47 AM
9c1ny's Avatar
cool, makes me feel a little better.....
Only the end fell off I got the float out.......
Your the only person so far who has replied to any of my posts who has had it happen to them........
Thanks for sharing man!
Old Mar 28, 2006 | 07:44 AM
MeanGreen97Z's Avatar
I'd advise against it.... pulling the pan isnt terrible.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
