Need help! Debris in my oil!
Ok my oil level sensor (the one above the drain plug) was leaking bad so I decided to change it........
I drained the oil and put the plug back in and changed the filter........ Upon pulling the old one out I found that the float was loose on the shaft and that the backing plate that prevents it from sliding off was missing........ The plastic on the float looks brittle and a little disentergrated also...... I am assuming it (the backing piece) is in the pan...... It is maybe 65% the size of a dime and maybe 1/5th an inch thick...... I am assuming its plastic, it is on the replacement anyways....... So what to do???? Is this thing big enough to cause major damage? If I fill her back up and drain her should it come out??? What are my options???? I really dont want to pull the pan Anyone experienced this? |
Re: Need help! Debris in my oil!
Same thing happened to me. When I pulled my old oil sensor out the float fell off in the pan. I just left it in there. It has been 3 years and 20k miles since then and no problems.
cool, makes me feel a little better.....
Only the end fell off I got the float out....... Your the only person so far who has replied to any of my posts who has had it happen to them........ Thanks for sharing man! |
I'd advise against it.... pulling the pan isnt terrible.
