need help connecting hoses, and how to get injector rails down?
Old Aug 10, 2005 | 05:05 PM
snakethis69's Avatar
i have pictures with edits on them on where to connect hoses for the throttle body. i wont get to do any runs this weekend like i had hoped cause i cant get the water pump in time. the pics are here. also how do i get the rear side of the injector rail down?
Old Aug 10, 2005 | 06:51 PM
Re: need help connecting hoses, and how to get injector rails down?
ok got all hoses done thanx to shoebox, but how do you get the rear fuel injecotrs down?
Old Aug 10, 2005 | 07:02 PM
Start with one side of the fuel rails, fitting all 4 injectors into the intake manifold bores and pressing it down, then go to the opposite side of the engine and line up the other 4 injectors and press that side home.
Possibly the rear of the rails is caught on something??
Old Aug 10, 2005 | 07:11 PM
should they just slip right in?
Old Aug 10, 2005 | 07:20 PM
It helps to put a little lube on the o-rings. The problem is that they are "angled" toward the center, so you can't force both sides in at the same time. Its easier to work one side at a time, at least from the times I've done it.
i tried slipping them in with the orings on the injectors it doesnt work. there is no way it will go down. nothing is getting caught
HectorM52
Jul 30, 2017 11:46 AM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
79 T/A
Feb 21, 2002 04:37 PM
