Need Help With Codes
Old Oct 8, 2007 | 01:27 AM
ELMAPA818's Avatar
I SCANNED MY 1996 CAMARO Z28 W/113K MILES. CODES IT READ--
1.P0300-ENGINE MISFIRE DETECTED.
2.P0400-EGR SYSTEM
3.P1371-DISTRIBUTOR INGNITION (DI) LOW RESOLUTION CURRENT
4.P1870-TRANS. COMPONENT SLIPPING
i DONT KNOW WHAT CODES "3-4" MEAN AND HOW TO FIX THEM. HELP!!!
Old Oct 8, 2007 | 04:16 AM
NemesisLT1's Avatar
#3 means that your opti-spark is going out, kuz you are geting a low current.... the optispark is called a distributor, and it could be causing your misfire. If your optispark is going out id make a good bet that it wont last much longer.
#4 means that something in your transmission is slipping...
Old Oct 8, 2007 | 06:58 AM
It isn't unusual for the code to show up for loss of the low res pulse (not current) from the Opti. I think it may set when the PCM has a hard time finding the signal on startup. Clear it and see how soon it comes back. If the code was active, the engine would not be running.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
