Need Help CODE 26 Error
Old Sep 24, 2003 | 11:36 PM
EC93TA's Avatar
Unhappy Need Help CODE 26 Error
Hi People,
I recently ran into a problem, my car for some strange reason starting giving me CHECK ENGINE light....I went ahead and plugged in the Code Reader and it gave me a CODE:26 error. Which is Quad-Driver module or Quad-Driver No.1 Error...
I am clueless when it comes to troubleshooting cars, I was wondering what exactly does this means, and how can I resolve this issue ?
Your help will greatly be appreciated...
Old Sep 24, 2003 | 11:37 PM
RamAir95TA's Avatar
A code 26 indicates a failure in the EVAP purge solenoid.
Old Sep 25, 2003 | 08:02 AM
It could be EVAP related, but also other things. The 1993 is a little different than later years.
Old Jan 4, 2005 | 01:33 PM
Bersaglieri's Avatar
Re: Need Help CODE 26 Error
How about on a 94? The wiring looks fine, should I just order a solenoid?
-Dustin-
Old Jan 5, 2005 | 12:12 AM
-Dustin-
You've asked this same question in 3 different threads.... I know I responded to you in one you originated, Shoebox responded in another where you highjacked it from the orignal poster, and now you've highjacked yet another thread and asked the same damn question.... What's wrong with the answers you've been getting?
Old Jan 5, 2005 | 05:05 AM
Fastbird93's Avatar
Take a look at the following links, they're directly out of my 93 Service Manual:
DTC 26 Description
DTC 26 Diagnostic Chart
Those should get you moving in the right direction.
Old Jan 5, 2005 | 08:55 AM
Now we're getting somewhere .
What does your manual show connected to the QDM #2 (DTC 27) and QDM #3 (DTC 28) circuits?
Old Jan 5, 2005 | 03:53 PM
Fastbird93's Avatar
DTC 27 Description
DTC 27 Chart
DTC 28 Description
DCT 28 Chart
How's that??
Old Jan 5, 2005 | 04:52 PM
It would be better if they were a little bigger (more readable), but I'm not complaining.
Old Jan 5, 2005 | 05:06 PM
Fastbird93's Avatar
Yeah, I tried to clean them up some as best I could, but my scanner is a vintage model. I just upgraded to XP and it won't even work now.
I've got the rest of the DTC charts in the SES Light link in my sig.
Old Jan 5, 2005 | 11:53 PM
Excellent.... I've been looking for those for quite a while, even asking repeatedly here on the boards. I have a 93 manual, but it is a "reprint" of the GM material `by Howell Engine Development, intended for their LT1 conversion harnesses, and it omits the QDM info, since I guess they figure anyone doing an LT1 swap in an older car won't be using most of those devices.
Thanks!
Rob: You ought to add some sort of note in the "93" column of your DTC code listing, indicating what devices are on each QDM.
Old Jan 6, 2005 | 07:48 AM
Thanks!
Good idea, Fred. Done.
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
nbm_2001_z28
Jul 5, 2002 05:10 PM
tbyrne
Jul 2, 2002 05:37 PM
felo72
Jun 10, 2002 01:46 PM
