need help!!! cnt figure it out
Old Jan 27, 2010 | 07:33 AM
Tanner_94_Z28's Avatar
ohk i had optispark problems by getting it wet and it wouldn't start and then it did so i drove the car to get a cat put on it at the muffler shop ( was open headers). i got a new cat put on but the car was missing bad and the guy said i should have that fixed. i drove it to my work and then the car wouldn't start so i changed the plugs and wires there one plug was broke i figured that was the problem. the car started but now my cat was glowing red i'm guessing from getting really hot? so i thought it was clogged so i cut it off and now it wnt go past 2 rpms won't accelerate or anything......is it my distributor? its my only explanation
Old Jan 27, 2010 | 08:12 AM
does anyone know anything??
Old Jan 27, 2010 | 08:45 AM
car still seemed like the car is clogged up but it revs up fine in park but when i put it in drive it bogs down and starts to drop oil pressure....as i drive it does fine but it seems like it can barely go and when i stomp it it barely accelerates
Old Jan 27, 2010 | 05:40 PM
SnakeOiler's Avatar
Sounds like symptoms of a clogged cat.
Old Jan 28, 2010 | 05:30 AM
Old Jan 28, 2010 | 05:32 AM
PS..... post it once.
https://www.camaroz28.com/forums/sho...d.php?t=734082
Old Jan 28, 2010 | 05:48 AM
Guest47904's Avatar
Guest
Your english/typing is not the most desirable.....to say the least.
So it runs like crap AFTER you cut the new cat off.
Since you have a CAI and you DOUCHED the motor, did you ever bother to check the air filter to see how wet it is?
FWIW, why would you put a new cat on an engine running like S@#T?????? Any poorly running engine can and usually does trash the cat.........
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
NewsBot
Sep 14, 2015 02:02 AM
