Need help..car won't start!
Old Mar 15, 2010 | 01:33 PM
myswt30th's Avatar
I just changed my opti...it came apart from the 2 main screws that hold it together....in less than a year! I put everything back together. I went to start it...battery was dead....i jumped it off. It started right up.....ran great! Drove it for about 30 mins.....turned it off to fill up the radiator some more.....battery was dead....sure no problem. Had it tested....it was pretty old....it came back no good! Easy enough so I put a brand new one on. I turn the key on...push in the clutch...the fuel pump turns on,dash lights come on....not a sound/click/interference!
I have checked for starter relays,fuses....couldn't find any? cheked all other fuses for the hell of it. all i didat this point was change the stupid battery???
Any help would be greatly appreciated....
1997 LT1 M6 pcm tuned by PCM for less
Old Mar 15, 2010 | 03:42 PM
IceMatrix69's Avatar
Are you sure you have a tight connection at your battery? Is your security light on?
Old Mar 15, 2010 | 03:56 PM
grumpygreaseape's Avatar
have a helper turn the key while you use a test light and check for voltage at the s terminal at the starter. its the small one closest to the block.
Old Mar 16, 2010 | 04:32 PM
myswt30th's Avatar
no signal to the purple wire?
i have power going to the starter...but no signal! any chance of the ignition control module going bad?
Old Mar 16, 2010 | 04:34 PM
myswt30th's Avatar
sorry...meant ingnition switch?
Old Mar 16, 2010 | 05:18 PM
yes you could have ignition switch issues. you could have clutch interlock issues, you could have neutral safety switch issues. security issues. turn the key to run and using test leads or a remote start switch-jump power to the s terminal and see if it starts up. take it out of gear or make sure its in park. then at least you know it will start with the battery/connections that you have. after that you need to start backprobing the harness and see where the start signal is getting lost. no security light? is it an automatic or a manual??
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
