need help.. car threw a p1133 code
Old Aug 25, 2009 | 09:49 AM
dragginS10's Avatar
Hey my car had a SES light on so i went to auto zone to get it checked and it was a p1133. Definition bbho2s-11 insufficient switching.
Can any one help me on how i should go about this problem.
oh its a 96 z28 btw
Old Aug 25, 2009 | 10:53 AM
moparman's Avatar
Possible problem with the pre-cat oxygen sensor on the driver's side. Could also be O2 harness problem.
Old Aug 25, 2009 | 05:08 PM
Slow switching of an O2 sensor is usually caused by the sensor itself, typically due to contamination.
Old Aug 25, 2009 | 07:38 PM
ThreeHonks's Avatar
I had the same code a while back with BRAND NEW acdelco o2 sensors. The code can also be cause by an exhaust leak. I had a small leak because the band clamp on the header collector wasnt tight enough and the sensors itself were also loose.
After I tightened everything up, it went away.
Old Aug 25, 2009 | 08:10 PM
dragginS10's Avatar
I do see a pretty big hole right before the muffler. But its been there for a while and it hasnt thrown a code. Could this be the problem still?
Old Aug 25, 2009 | 09:07 PM
Exhaust leaks AFTER the sensor will no affect it, and will not "throw" a code. Exhaust leaks before the sensor can cause a "false" lean condition. Not sure why that would cause slow switching, though.
Old Aug 25, 2009 | 10:04 PM
dragginS10's Avatar
ok so it can either be an exhaust leak before the sensor or the sensor itself?
Old Aug 26, 2009 | 06:25 AM
ThreeHonks's Avatar
Yes. I have 2 almost new Delco O2's if you need them. $30 shipped for both. My car was tuned in open loop so I no longer have any type of oxygen sensor any longer
Old Aug 26, 2009 | 07:09 AM
dragginS10's Avatar
alrite sounds good but first i want to check if its an exhaust leak. How do i do this should i just bring it to meineke?
Old Aug 26, 2009 | 07:11 AM
ThreeHonks's Avatar
Make sure the sensors are tight in the bung, but really if you are running stok manifolds and y then it shouldnt leak if in good shape. If running aftermarket, take a look near the slip fit connecion and make sure all is tight
Old Aug 26, 2009 | 09:21 AM
dragginS10's Avatar
alrite thanks alot
Old Aug 26, 2009 | 11:28 AM
dragginS10's Avatar
alrite so i just got back from meineke and there are no exhuast leaks. Threehonks where are you located b.c i want those sensors but i leave for school on friday.
Noenav
Mar 1, 2019 07:38 AM
Dec 1, 2014 08:08 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
