lifter tick bad lifter?
Old Aug 26, 2009 | 12:48 PM
quack's Avatar
how can you tell if a lifter is bad. 97 lt1 ,580 lift cam 1.6 roller rockers. i have them at 1/4 pass 0 lash. i'm going to try 1/2,3/4 see if that helps. or should i pull intake and replace? it's the 4th one on drivers side.
Old Aug 26, 2009 | 12:57 PM
Maverick_997's Avatar
if you tighten the suspected loose rocker arm, and the ticking sound goes away for a couple of seconds then comes back that would be a bad lifter... do this while the engine is running.
my rockers are tightened 1/2 turn past zero lash and i have had no noise what so ever.
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
KamikaZ28
May 28, 2015 12:45 AM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
importkiller94
Jan 17, 2015 09:03 PM
