need help with canton pan
Old Apr 1, 2003 | 10:26 PM
4th-gen-formula's Avatar
I just got my headers today after waiting a long time. I've had the engine sitting in my garage for about 3 weeks. Anyways, it has a canton road race pan an the guy that built the engine daid something about having to put spacers between the motormounts so the front of the pan wouldnt hit the steering cylinder (which it does b/c I tried without the spacers first). I was wonderg ho do you put spacers under it. The mounts are at an angle and if you put spacers on then the holes won't line up. I've done a search and didn't find anything. I was wondering if anyone out there can help me?????????
Old Apr 2, 2003 | 06:10 AM
Someone has got to have had this problem before. How do i fix it. I'm kinda in a hurry to get this car finished. I still need to put the transmission in and the rear end. Why did canton even make this pan knowing that it hits.
Is it ok if it just barley touches or will it rub a hole in the pan???
need help ASAP
Old Apr 2, 2003 | 12:20 PM
Xscream's Avatar
On my canton and headers they fit fine. I had to remove the steering shaft and that was it
Old Apr 2, 2003 | 12:32 PM
Gripenfelter's Avatar
Dunno about the spacers but I know Nu-Tekmotorsports.com sells a pan thats modified to clear the shaft. Not that it helps you now.
I
Old Apr 2, 2003 | 01:08 PM
Chrisbequick's Avatar
How bad does it interfere? Could you just dimple the pan for clearence?
-Chris
Old Apr 3, 2003 | 10:18 AM
Xscream's Avatar
I
I keep hearing about there pan but the one my buddy got wasn't much differnt and actually was just as much of a PITA to work with
2QUIK6
Sep 17, 2016 02:31 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
wbspoon
Sep 19, 2015 08:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
