need help with cam
Old Mar 30, 2004 | 03:13 PM
toquickforyou's Avatar
Question need help with cam
Hey need help picking cam, what would yall think about this? 96 camaro lt1 6speed, headers, no cats, descreened maf, tb bypass, custom tune to cam.
HYDRAULIC, 246 at 50 duration, .515 lift and .343 at lobe on in. and exh. 108 lsa mostly daily driver. 373 gear
Old Mar 30, 2004 | 05:21 PM
rskrause's Avatar
Moderator
Re: need help with cam
Almost any LT1 combo will run better with a "split pattern" cam - more exhaust duration tham intake. Also, that is a hella big cam for a car that will see street time, especially with stock heads. Basically, I think it will suck. No vacuum and not much power. You need a split pattern, less duration, and more lift. You also didn't specify the LSA, which is extremely important and gave no info about how you plan to use the car. Also, knowing your rear end ratio would be useful.
Rich Krause
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
