Need Help Asap With Motor Jacking!!!
Old Jan 13, 2005 | 12:45 AM
  #31
dover179's Avatar
Re: Need Help Asap With Motor Jacking!!!
Originally Posted by Birdman7389
be patient with your car, you dont wanna fudge anything up. Are you trying to install your headers on a set of ramps?
Let the engine ALL THE WAY DOWN. Jack it up a LITTLE bit, and try to tap the bolt out with a hammer. Trust us, it will come out.
Sounds like you have your hands full trying be be done by tomorrow, if you were closer I would just come over and start throwin wrenches
The clearness thing was my fault, I asked if he was sure he was on the motor mount, but I accidentally deleted it when I edited my post.
Old Jan 13, 2005 | 12:46 AM
  #32
dover179's Avatar
Originally Posted by fredmr39
well i tried oil pan with wood for a wuick second, no dents or whatnot - so I should use the tranny like the first pic, correct? Also - Car is on wheel ramps, does it need to be higher??
Ramps should be good, I used jack stands, probably not as high as ramps. If the oil pan isn't denting or bending, it SHOULD be ok.
  #33
fredmr39's Avatar
ill give that a try and be back
Old Jan 13, 2005 | 12:48 AM
  #34
dover179's Avatar
BTW, don't try to force the bolt out without some pressure taken off the bolt. Don't want to screw up the threads. Have you tried spraying a little WD-40 in there? Might help.
Old Jan 13, 2005 | 12:52 AM
  #35
fredmr39's Avatar
no - i can see, the mounts DO NOT MOVE AT ALL when i jack -- should the car be higher than ramps before jacking? The entire car moves right away, i NEVER see alignment change on holes AND the part of the bolt towards the back of the car IS ALWAYS smashed against the top ot the hole
Old Jan 13, 2005 | 12:54 AM
  #36
dover179's Avatar
Sounds like it's seized in there. If you can fit a pry bar or screwdriver in there, you might try to pry it down.
Old Jan 13, 2005 | 12:59 AM
  #37
dover179's Avatar
Ramps should be fine
Old Jan 13, 2005 | 01:02 AM
  #38
Birdman7389's Avatar
Your trying to install headers right?
Old Jan 13, 2005 | 01:04 AM
  #39
dover179's Avatar
Ya, he's putting in lt's and needs to get out the motor mount bolt to raise the engine for a little clearance.
Old Jan 13, 2005 | 01:09 AM
  #40
dover179's Avatar
any luck?
Old Jan 13, 2005 | 01:13 AM
  #41
Spinner's Avatar
Hammer the bastard out. It's a damn motor mount bolt, probably one of the strongest bolts on the car. I've knocked mine out and in numerous times.
Old Jan 13, 2005 | 01:24 AM
  #42
fredmr39's Avatar
No luck - seems like its bent? Holding too good to just be seized up - WD40d the hell outta it, im gonna take the hammering advice - THANK YOU GUYS FOR YOUR SUPPORT -- if all else fails, how bad is loosening K member? hOH yea, THE ONLY thing stopping this install from being completed 8 hours ago is the AIR hookup on the pass side header - had i known this, i would have gone without emissions
Old Jan 13, 2005 | 01:27 AM
  #43
dover179's Avatar
The k member is only 3 bolts per side. It's described in the site I posted a bit ago. I HAD to do that on mine. I don't know how much room you'll get without the motor mount being disconnected, but it's worth a try. And btw, no emissoins is the way to go if you don't have to worry about testing. Cleans up the header area real nice.
Old Jan 13, 2005 | 01:29 AM
  #44
fredmr39's Avatar
I agree 1000% its the way to go - summit had them backordered till 1/12 (yest) tho and i got these a while ago, wanted to get em in before i go back to school -- ill try K member
Old Jan 13, 2005 | 01:31 AM
  #45
dover179's Avatar
I assume you have a buddy helping? If so, undo the 3 bolts and pry down on the k member from the wheel well and try to slip the header in. It's not going to move a whole lot, probably about 3/4 of an inch, but every centimeter helps!
