Need Help Asap With Motor Jacking!!!
Re: Need Help Asap With Motor Jacking!!!
Originally Posted by fredmr39
THis website totally mislead me then - hope i didnt fudge the tranny
This may help, it's the page I used to help me last week when I did mine. It's for Jet hot's but should be the same for almost all headers.
http://www.theheadfl.com/jethotlt.htm
NO luck, with the first half inch of jacking, the entire car raises - HOW HIGH SHOULD THE CAR BE BEFORE JACKING? AS POSTED, IT IS ONLY ON WHEEL RAMPS NOW -- i hope i get this soon...
ok - on that site - what is the first illustration for with the big wood piece, and what is the one further down with the calc book? (link above)
Should I be able to just twist it out of BOTH HOLES BY HAND or JUST ONE HOLE -- WILL FORCING IT OUT of the first hole be bad? It WILL turn if i use a rachet
That I am sure about, got the 18 mm nut off, other side is 15 mm bolt
) The calc book is used to get an extension on the jack, same as a block of wood. well, the bolt "should" slide out when all is aligned, no turning necessary.
Let the engine ALL THE WAY DOWN. Jack it up a LITTLE bit, and try to tap the bolt out with a hammer. Trust us, it will come out.
Sounds like you have your hands full trying be be done by tomorrow, if you were closer I would just come over and start throwin wrenches
well i tried oil pan with wood for a wuick second, no dents or whatnot - so I should use the tranny like the first pic, correct? Also - Car is on wheel ramps, does it need to be higher??
