Need Help Asap With Motor Jacking!!!
Old Jan 12, 2005 | 11:50 PM
fredmr39's Avatar
How far before the bolts line up?? Ive gove over an inch, the entire car is raising....the bolt is just as easy to turn the whole time, so it isnt getting easier - should it slide outta both holes really easily? Or do i have to force it thru the first then align it only for the second one? Also, do i have to remove both motor mounts if i just want the pass side raised??
Old Jan 12, 2005 | 11:54 PM
fredmr39's Avatar
Re: Need Help Asap With Motor Jacking!!!
Transmission and all move - whole car lifts, bolt does not slide out easily nor do mounts move - help please - need car running by tomorrow = (
Old Jan 13, 2005 | 12:07 AM
fredmr39's Avatar
Also car is only on ramps - does it need to be higher?
Old Jan 13, 2005 | 12:08 AM
Birdman7389's Avatar
A little confused here. You are trying to get your motor mount bolt back in? The motor does not need to be jacked up much for the holes to line up. It should in fact sit on there fairly well, with minimal jacking. Play with it a little, there is a sweet spot where it will slide in and out fairly easy. If you clarify what it is you are doing then we can help more.
Old Jan 13, 2005 | 12:09 AM
fredmr39's Avatar
im trying to get it out, jacking is just moving the entire car up and down, the motor is not moving
Old Jan 13, 2005 | 12:12 AM
dirtybird96's Avatar
sounds like you have it up too far
Old Jan 13, 2005 | 12:13 AM
fredmr39's Avatar
The front side seems fairly centered while the side towards the back of the car is at an angle
also - where exactly should the wood be and how large a piece of wood is needed?
Old Jan 13, 2005 | 12:14 AM
fredmr39's Avatar
even fully lowered it wont budge and looks the same both sides
Yep, if its moving the car, you need to come back down with it. It only takes a little bit to get the weight of the motor off the mount. After the nut is run off, you may be able to wiggle it out, or get a hammer and tap it out.
Old Jan 13, 2005 | 12:15 AM
dover179's Avatar
definately. drop it all the way down then up about a 1/4 of an inch. Doesn't need to go up much at all. I hope you get it done
Old Jan 13, 2005 | 12:16 AM
fredmr39's Avatar
Do Both Mounts Need To Be Unbolted? Or Just One?
Old Jan 13, 2005 | 12:18 AM
fredmr39's Avatar
all install guides is see say just unbolt one side? is it assumed the other side as well? It would make sense to me since you're jacking in center on trans - should the wood touch oil pan at all? Why is this so difficult for me
dover179's Avatar
Just do the side you're working on, leave the other one alone till you're putting that side in.
Old Jan 13, 2005 | 12:20 AM
dover179's Avatar
I put a block on the jack and jacked on the oil pan . It worked, but I would probably do it on the tranny.
Trust him on this, if you get both of them undone at the same time you will struggle all night to get them both lined up again.
