NEED HELP ASAP!!! which cam to use?
Old May 2, 2005 | 04:16 PM
speedracer69's Avatar
i have a 1994 camaro z28 with a 6speed.
i have a 383ci with ported heads 1.6rr 58mm TB ele-pump
its all the good stuff inside- its set up for the bottle 200shot.
which cam should i go with??? i have a comp cam 306 and have been told that its not the best.
what should i do???
Old May 2, 2005 | 04:48 PM
Pasky's Avatar
Re: NEED HELP ASAP!!! which cam to use?
#1. This is definatley not advanced tech.
#2. Give Brett Bauer or Joe Overton a call.
If your not into the "Top secret cam specs":
#4. Call combination motorsports and have them give you a hand.
#3. Call comp cams or crane cams and see what they recommend.
CMSDave's Avatar
I tried pm'ing you but you are full.
My guess is that they will move this into reg. tech.
Old May 2, 2005 | 05:33 PM
you can pm me now...
it said "Advanced tech discussion. Stroker motors, Major rebuilds, etc"
its a strocker motor......... sorry
just want to know what to use..
Old May 2, 2005 | 07:23 PM
marshall93z's Avatar
[QUOTE=Pasky#2. Give Brett Bower or Joe Overton a call.
[/QUOTE]
Bret will sh*t when he sees that!
Old May 2, 2005 | 07:36 PM
Pasky's Avatar
My bad, spelled it wrong?
Old May 2, 2005 | 08:40 PM
OldSStroker's Avatar
You were closer:
Bret Bauer
Old May 3, 2005 | 10:47 AM
ok what cam does anyone about like me use??
Old May 3, 2005 | 11:01 AM
Gripenfelter's Avatar
huh?
Old May 3, 2005 | 12:26 PM
haha sorry....
what i meant to say was
what cam is everyone using in thier car?
here is some info i have got....
one said to use a 230-239 .551 .571 114lsa
or
234- 242 .539 .558 at 112lsa
what do you all think??
Old May 4, 2005 | 12:13 PM
ttt need help
Old May 4, 2005 | 12:42 PM
Kurt Crosbie's Avatar
I'm using a 234/242 on a 355. I would imagine you could go much bigger with a stroker motor. My buddy put a 233/239 in his and he is not satisfied at all. I assume something in the 240 range would do it on the intake side, but you will have to consult the pros.
Old May 4, 2005 | 12:47 PM
rskrause's Avatar
Moderator
Not enough info to even guess. Let's start with the following: you planning an HR or a SR cam? What heads are you using? How much street vs. track time? How important is drivability/low speed operation? What is the compression ratio, and so on.
Rich
Old May 4, 2005 | 12:52 PM
SStrokerAce's Avatar
Heads, compression, gear, tranny, stall etc.... Those all play into it.
Add in what the car is used for, what you want for drivability etc...
You really can't pick a intake and exhaust duration out without having quality flow numbers.
Bret
Old May 6, 2005 | 11:53 AM
well the heads are stock with a port job, also installed are 2.02s and 1.80s
the car is a 1994z28 with a 6speed, soon to be a 9inch with 3.90's and a twin disc
its running 10:5.1
i dont care how it is one the street because i have another car to drive..
thanks for all of your help
