need help asap
Old Nov 10, 2012 | 05:20 PM
kwik_ta's Avatar
need help asap
im about to board a plane to go see a 1997 camaro ss. its a true ss with 13k original miles. the owner just phoned me saying the oil cooler broke. i cant find a part or labor line item. how much does it cost to have a shop do the install?
Old Nov 10, 2012 | 06:30 PM
RUDEDOG's Avatar
Re: need help asap
Just remove it. You are better off without it. They can clog up and cause problems. Do a search of this forum and you will find some info.
Old Nov 10, 2012 | 09:20 PM
bw_hunter's Avatar
Re: need help asap
Two things:
I had my car for ten years now and the oil cooler has never done anything untoward. I'll bet others will echo this.
I don't know what there's to break. The system consists of hoses to an adapter sandwiched between the oil filter and the engine.
The problem may be a leaky line or a loose adapter...nothing requiring you to remove it...and easy to fix.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
