Need help ASAP!
Old Jun 9, 2004 | 05:50 PM
Formula03's Avatar
Need help ASAP!
Ok I built a new motor for my car and I put it in and I have everything hooked up. I was getting ready to start it and I hooked up the battery and sparks started flying and when the battery was hooked up I heard a sound that was like a vaccum cleaner I didnt try to start it I just disconnected the battery. The car doesnt have any emissions stuff left on it. Any help would be greatly appreciated.
Old Jun 9, 2004 | 05:57 PM
z71camaro's Avatar
You did have the key off right?
Old Jun 9, 2004 | 06:02 PM
Formula03's Avatar
Yeah it s off, it sounds like it is trying to start itself when I hook up the battery.
Old Jun 10, 2004 | 10:17 AM
Bad64chevelle's Avatar
Check the wiring on the starter, you may have the wrong wires on wrong prongs...that happened with my Chevelle, just switch the wires up!
Old Jun 10, 2004 | 10:47 AM
97-1LE's Avatar
The wires on the starter may be touching each other.
Old Jun 10, 2004 | 11:00 AM
Lyle A's Avatar
Definitely the starter. The solenoid may be stuck. I had a problem similar to that. I drove the car about 3 blocks shut it off and heard a noise just like that. I popped the hood and noticed that the starter was running but not engaged. I scrambled to disconnect the battery. I could smell the motor windings burning. It stopped on it's own but runs a little slower now. At least it still works.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
