need help....again. :-(
Old Apr 15, 2006 | 07:56 AM
  #16
Re: need help....again. :-(
Your original post is not clear, making it very difficult to even get started on solving the problems.
i have just put on my intake and throttle body.
Did you install a cold air intake or an intake manifold?
Did you remove, clean and reinstall your stock throttle body, or did you install a new, aftermarket throttle body?
The answer to those questions will help determine where the oil might be leaking from, and why the idle is too high.
i saw that it leaked out a large amount of oil.
Where did you see this oil...... front of the engine near the throttle body, or back of the engine where the intake manifold joins the rear edge of the block, or somewhere else?
Old Apr 15, 2006 | 08:02 AM
  #17
When you accidentally "double post", it is in your own interest to "DELETE" the extra posts. Now you have two threads going on the same subject, and people responding to one thread are not getting the same info as people responding to the other thread.
I'll "merge" the two threads. In the future, when you double post, click on the "EDIT" button, then click on the "DELETE" button.
