need help 94 z28 distributor
Old Mar 15, 2011 | 05:49 PM
mannys6speed's Avatar
Exclamation need help 94 z28 distributor
I just got my car back from the chevy dealer, they told me that my distributor and water pump were bad. I wanted to know how do I replace the distibutor and how hard is it??
Old Mar 15, 2011 | 05:51 PM
chevy_dude97's Avatar
Re: need help 94 z28 distributor
if you are good with tools and mechanics its about 5-6 hours. If you have ever removed a pully or water pump before it is very easy.
Of the 2 cars I pulled em from I only needed a pully puller for one of them. You gotta take off the intake, drain the water, move the air pump out of the way remove the water pump, then the belt and crank pulley. Then you can get at the opti. After doing it once I was able to r2 the second one in less then 3 hours including the run to the autoparts store.
Old Mar 15, 2011 | 05:58 PM
OK thanks alot, It shouldn't be too hard then. The dealer was trying to charge me $3,000 to change it.
Old Mar 15, 2011 | 05:59 PM
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=517&t ransactionid=1300229986-24153190194&posted_by=chevy_dude97_camaroz28.com[/autostream]
try this video, I know its on a corvette but its just about the same.
Old Mar 23, 2011 | 02:29 PM
Exclamation Re: need help 94 z28 distributor
Would I need to set up the timeing on the opti?? or does it just go in place??
Old Mar 23, 2011 | 03:04 PM
GRIDERMAN87's Avatar
It goes in exactly where it needs to make sure you align the marks or it won't run and ya gotta start over, while your down there you might wanna upgrade the timing chain there pretty cheap and it would be good upgrade to make especially if your ever planning on turnin some rpm
Old Mar 23, 2011 | 03:19 PM
how do u install timing chain?? is it easy??
Old Mar 23, 2011 | 10:08 PM
While it may appear the splined drive shaft will only assemble to the cam sprocket in one position, it is very possible to assemble it incorrectly. Happens all the time. USe Shoebox's info, and check carefully as you assemble:
http://shbox.com/1/93-94_opti.jpg
Why do you want to change the timing chain? Not required if all you are doing is changing the water pump and distributor. Again, Shoebox has a guide to a complete cam swap, which will have info regarding removing and reassembling the timing chain.
http://shbox.com/ci/cam_removal.html
http://shbox.com/ci/cam_install.html
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 5, 2015 07:14 PM
brentbrowning01
Dec 3, 2014 10:36 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
ScottZ
Mar 3, 2004 01:34 PM
